Magnetos are totally separate from all other systems in all tractors. The mag is self powered and will be ruined by connection to any external voltage. The Kill switch is a grounding device that shuts off the mag to stop the engine. If it runs and charges, all is well. If it does not not charge we can help fix that easily. The process is one of decision, either the system should be upgraded to an alternator, or switched to a 12v generator. All light bulbs must be changed, and (if kept as a generator, the regulator must be replaced. If alternator, (simpler in many ways, and more reliable) the system will need to be changed to negative ground. and a method of turning on the alternator put in, and the amp gauge wiring changed so it reads in the correct direction. Let us know what the situation is. Jim
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
