Re: IH560 hydraulic oil path and icing fix idea
Posted by Owen Aaland on January 16, 2015 at 17:22:35 from (216.47.34.37):
In Reply to: IH560 hydraulic oil path and icing fix idea posted by MaxDamage on January 16, 2015 at 15:32:23:
A couple of misconceptions.
First off, ice does not float on oil. Water settles to the bottom and stays there even after it freezes.
Second, the oil pickup tube inlet is located near the bottom of the rear frame between the bull gears. The tube is routed so that it goes above the oil level before the outlet appears in the filter cavity.
