Re: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!!
Posted by pete 23 on February 01, 2015 at 10:17:03 from (173.87.146.176):
In Reply to: Farmall B Leaking gas at carb????? Very frustraited!!!!!!!!! posted by rjc2rjc on February 01, 2015 at 09:59:38:
OK, does it leak while running. When you are cranking, gasoline is and has to be pulled from carb into manifold. If it does not immediately start, there will be some excess gasoline that does not make it up into engine. Slow cranking speed may be your problem. This happens on all carburetors but down draft carburetors don't show it as it goes directly into the engine. If it does not leak while standing, not running, or leak while running I say carb is ok. Also, do you have a packing in the drip plug hole. That drip plug is to slowly allow excess fuel to rid itself while shut down but if open hole gas will flow freely. A carburetor is a rather crude device to say the least as you can make an engine run by just squirting gasoline in with a oil can.
  Upload Photo  Select Gallery Photo  Attach Serial No List
