Re: Farmall A convertion to 12V negative ground
Posted by Bob on February 02, 2015 at 18:12:22 from (64.255.159.192):
In Reply to: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 17:58:00:
What you are doing has been done many times and does work.
The primary of the coil INSIDE the mag needs to be disconnected from the points and condenser (which presumably has already been done).
And you are correct in the power being connected to the (+) side of the coil.
You also need a "true" 12 Volt coil, or a ballast resistor ahead of a 6 Volt coil.
  Upload Photo  Select Gallery Photo  Attach Serial No List
