That brown goop never gets close to any small oil passages. You only see it in places where no oil circulates and that are away from engine heat. Places like the top of dipsticks like in this case and oil fill ports. There's none of that goop in the crankcase. No need to change the oil, an oil analysis would show no fuel or coolant in the oil.
Any place that warm, not hot oil circulates will be clean.
Yes, running the engine for longer time periods helps, as does covering the entire radiator to raise engine temp. Idling the cold engine actually makes the accumulation worse, lowers engine temp more. But running ANY engine when it's really cold is hard on it.
It's funny.... You think something harmless like this is abuse and is bad....yet you store ALL your equipment outside in the weather which is the worst thing you can do to equipment!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
