Re: Super A - Wheel Configurations
Posted by Haas on January 25, 2001 at 19:25:33 from (129.37.117.79):
In Reply to: Super A - Wheel Configurations posted by David A on January 25, 2001 at 09:06:42:
Congrats on getting the front axle adjustment done. I never did get there on the 140 I had. As far as the rear wheels go, I used a 60 inch mower on a Super A and then a 140 for 18 years. I set the rear wheels concave side in and the rims out as far as they would go. That just about matches the 60 inch cut of the mower, maybe just a tad wider. Please be sure you keep the heavy cast wheel on the righthand side and the pressed metal one on the left. That cast wheel is a weight to help stabilize the tractor offset. I commend you on setting the rear wheels out as much as you can. You need that for stability if you are going to be mowing on any slopes.
Post A Followup
: Re: Re: Super A - Wheel Configurations
