Re: What makes a gas engine run rich
Posted by dick on March 02, 2001 at 18:58:59 from (63.120.111.98):
In Reply to: What makes a gas engine run rich posted by Gene on March 02, 2001 at 18:02:00:
If you would give a bit more information on what you've tried so far that hasn't worked, your chances of getting useful feedback would go up considerably. What plugs are you using now, and which have you tried in the past? Have you removed a plug and looked at the spark to see if it's weak? Have you tried to operate it without the air cleaner hose attached? Is the choke plate operating properly; especially, is it opening all the way? Does the air intake to the carb. look wet. If so, under what conditions? Does the tractor appear to operate differently with the air cleaner connected (if so, it may be partially plugged - not a bad idea to pull it off, fill it with kerosene or diesel to clean its screen, and drain it good before reinstalling it in any case - supposed to be done periodically, but probably hasn't been since the tractor was new). How far off their respective seats are your adjustment screws on the carb. set? Have you REALLY tried to move these as close to closed as the tractor will tolerate and still run? These control the fuel/air ratio, and are the most "obvious" source of too rich a mixture. Have you looked for leakage around the intake manifold? Unlikely, but a leak here could necessitate overly rich adjustment at the carb. and result in fouling at the plugs. Have you checked the timing and the valve lash lately? Might be most anything on this list, which hopefully is helpful - let us know how you make out.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
