HELP!!! CUB PROBLEMS
Posted by Mike Johnson on April 25, 2001 at 06:23:24 from (204.155.48.28):
I did a compression test and got these results!
#1 cyl - 80 lbs.
#2 cyl - 65 lbs.
#3 cyl - 110 lbs.
#4 cyl - 100 lbs.
What would you recommend doing first, and what do you think is the likely culprit. It does not smoke but has lost a lot of power.
Post A Followup
: Re: HELP!!! CUB PROBLEMS
