Cub will not start now.
Posted by Ryne on July 16, 2001 at 05:42:54 from (216.174.25.85):
Ok, here is the problem. I just purchased a 1952 Cub and have know idea what I am doing. I purchased the Service Manual and Operators Manual and started doing the regular maintenance. The battery would not start the tractor after the first time each day. So I installed a new 6v battery. However the problem continued. So I read the old postings and change the old battery cables I used 2 gauge cable. Then I changed all the plug cables, coil, distrubutor cap, rotor, points, plugs and contensor. Closed up everything. You guessed it,dead. The starter makes a noise but that is it. So what did I do?
I have some questions.
Which plug cable going on the #1 cap hole, is it the 1 plug I had trouble seeing it in the book?
Did I put the wires in the wrong spot?
The coil has a positive and negitive pole I put the wire from the side of the distributor to the positive pole assuming it was the ground wire was this correct?
When setting the gap on the points I put the rotor in the #1 position I was not sure but is that the highest point? The point were the gap is the largest?
Did I not put the plug wires into the distributor all the way?
I could not check all these things becuase the battery went dead.
Please help me get this great tractor running again.
Post A Followup
: Re: Cub will not start now.
