Charge it, please...
Posted by HavinFuninMo on August 13, 2001 at 11:50:02 from (64.196.152.17):
Hey,
Finally got around to replacing a bad voltage regulator on my F - 140. I am having a hard time finding a 6 volt, negative ground regulator. My local Case IH dealer tells me that they never made a 6 volt negative ground system. Is that so? The system sure looks original. If I can't find a negative ground regulator(Have been to all the local auto parts & tractor supply stores), what do I have to do to change it to a positive ground system?
Thanks in advance for your help.
Post A Followup
: Re: Charge it, please...
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
