Re: M Brakes
Posted by Farmer Bob on September 02, 2001 at 10:33:14 from (208.49.9.55):
In Reply to: M Brakes posted by pete-Tex on September 02, 2001 at 09:33:29:
Pete, If you travel anywhere in road gear with those brakes BE CAREFUL! With one not working properly you run the risk of a possible roll-over if you had to stop quickly. You can try to adjust the left one to tighten the band so it makes contact with the drum when braking. But I would recommend that you either have the drum turned, unless you like buying linings, or find another drum. Brakes are important and are suppose to be adjusted evenly so both brakes are equally effective in stopping the tractors movement. Don't meet your maker prematurely.//FB
Post A Followup
: Re: Re: M Brakes
