300 12v conversion
Posted by makin,hay on March 16, 2009 at 06:11:00 from (69.95.141.133):
Hi, does anyone know the best way to convert a Farmall 300 from 6vdc to 12vdc? Are the original starter and points and condensor still useable? Also the voltage regulator? If the 12v alternator has a built in reg. can the original be eliminated? Thanks
