Should not be possible
Posted by jdemaris on February 25, 2007 at 06:45:30 from (66.218.11.250):
In Reply to: glow plugs burn up posted by jackinactonca on February 24, 2007 at 23:09:43:
B-275 uses a 12 volt system but runs the glow plugs at only a couple of volts. The glow-plugs are rated at less then one volt - 9/10 of a volt to be exact. .9 VDC at 40 amps, 18 mm thread with a 13/16" hex. Old number (from the 1960s) was Champion AG28. Later got changed to CH28, then #155, etc. With the B-275, the glow-plugs are all run in series, along with the fifth heating-coil inside the dashboard. If you've got them hooked correctly, it's not possible to burn them all up. Since they are in series, as soon as one goes bad, the rest no longer get any power. Glow plugs are Champion AG28, CH28 ( #155). Bosch # : 0250001001 or 0250001010 Lucas: DS104 Beru: 214GK
Same plugs used in: MERCEDES (Series) 17ODa. 17ODb, 17ODS, 17OS-D,180D,18ODb D5, 190D, 19ODb INTERNATIONAL BDI44, BD154, B250, B27, B414, 424, 444, 2424. 2444, 3414, 3444, 364, 384, TD-5, 500, Series, 7000 MERCEDES-BENZ Unimog: 411A, 8, C OM Series 83- MEVOSA OM636 SEAT 132D, OM636 THERMO-KING NWD, UWD(Series)
