Re: 160 degrees on a C-123 block! :)
Posted by Bob on April 07, 2007 at 22:40:53 from (69.178.229.154):
In Reply to: Re: 160 degrees on a C-123 block! :) posted by Bob on April 07, 2007 at 22:37:17:
P. S....
As long as the coolant isn't boiling; you're not going to hurt the engine. Getting the temp up into the 180 to 195 range is BETTER for the engine than running cold.
