Re: Farmall M Rained In
Posted by Janicholson on May 07, 2007 at 19:18:48 from (66.173.50.163):
In Reply to: Farmall M Rained In posted by steve laaveg on May 07, 2007 at 19:09:28:
If it started, that blew the water out of the exhaust. If it did not, I Would (now) loosen the drain plug from the oil pan and just crack it open into a pan to see if water got into it. Probably not much. Once that is done, Pull the spark plugs and spin it over for 10 seconds. Then reinstall the plugs and start it. (be sure to keep the wires organized. Don't fret, it will be OK. Fix the Pipe, It is 2" NPT tapered pipe thread. Rent a Tap to run the threads, and put a new pipe in it about 9 to 10" long. Use silver antisieze on the threads to allow future removal. JimN
