Re: what size speedi-sleeve for super c crank pull
Posted by El Toro on June 06, 2007 at 13:22:19 from (64.12.117.8):
In Reply to: Re: what size speedi-sleeve for super c crank pull posted by Mark Doud on June 06, 2007 at 11:46:26:
You need to use the seal that comes with speedi sleeve. Hal
