Re: what size speedi-sleeve for super c crank pull
Posted by Mark Doud on June 06, 2007 at 14:27:22 from (71.58.88.206):
In Reply to: Re: what size speedi-sleeve for super c crank pull posted by El Toro on June 06, 2007 at 13:22:19:
Ok thanks.
I Didn't know that was the case. I should be buying stock in Cng.
