Farmall Tractors Discussion Board
Re: My M won't move!
Posted by big fred on May 13, 1999 at 12:35:22:
In Reply to: My M won't move! posted by Bill on May 13, 1999 at 12:25:57:
On my B, It was pretty obvious what the position of the gears should be for neutral. I put the transmission gears in their neutral position and the shifter in neutral, and put it together. It took a couple tries to get it back together without moving a gear out of position, though. I could tell I had it wrong, 'cause when I "bumped" the starter the engine wouldn't crank.
Post a Followup
: Re: Re: My M won't move!
