Farmall Tractors Discussion Board
Re: Another charging followup. Found the culprit
Posted by RKS on May 22, 1999 at 10:02:30 from (152.204.202.157):
In Reply to: Another charging followup. Found the culprit posted by The Red on May 22, 1999 at 09:06:12:
at close to full charge, you are probably going to still get the "dance." Every time you shut down and restart, you're using enough current to take the battery down just below full charge, and the VR will "pass" the current. If you are well enough into "discharge", the VR will allow the current flow through the ammeter to be steady. Near full charge, the VR will equivocate, and play the dance with the ammeter. If you want steadier, you could go for an electronic VR, but then the "Great-and-Powerful Oz" would assume you have violated some Farmall code, and not let you sleep.RKS
Post a Followup
: Re: Re: Another charging followup. Found the culprit
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
