Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Follow up -- got spark, got gas won't start.
Posted by RKS on June 05, 1999 at 19:55:02 from (171.213.123.178):
In Reply to: Re: Re: Re: Re: Follow up -- got spark, got gas won't start. posted by Larry on June 05, 1999 at 17:50:54:
don't have any problem with your approach Larry, but just wondering - - why would we "toast" a valve cover gasket just to isolate number one at TDC on the compression stroke? I suppose you meant if a further check of valve timing was required, huh? Do you agree that's not necessary if we only think the ignition timing is off by 360 degrees, or 180 in terms of the rotor? RKS
Post a Followup
: Re: Re: Re: Re: Re: Re: Follow up -- got spark, got gas won't start.
