Re: Re: Re: Bob M.( Crankshaft to Camshaft Timing )
Posted by Bob M w/link to photos on January 30, 2002 at 07:17:41 from (165.170.128.65):
In Reply to: Re: Re: Bob M.( Crankshaft to Camshaft Timing ) posted by Slick on January 29, 2002 at 18:36:29:
Hey Slick - Punch below for pix of the Super M cam gear replacement.
On mine I found damage (chipped teeth) to every timing gear except the governor drive. Was probably caused by the camshaft nut getting caught in the gear mesh after it unscrewed and dropped off. However the gear damage was not severe enough to warrant replacement. Also found damage (large chip) on the camshaft keyway. Installing a new cam gear, Woodruff key and keeper under the cam nut (which incidentally is LEFT-HAND threaded on the Super M) fixed it to like new. The tractor has run flawlessly since (2 years now). ...Bob M
Post A Followup
: Re: Re: Re: Re: Bob M.( Crankshaft to Camshaft Timing )
