H bull gear/axle removal
Posted by Mike ISW on March 29, 2002 at 11:37:59 from (205.188.197.49):
Got the top cover off my trans/diff today. I need to replace the outer bearing on the r/h bull pinion shaft. I need suggestions on removing bull gear and axle. If I remove the outer bearing retainer on the axle will I then be able to push out axle far enough to remove bull gear from axle splines? Does the whole axle carrier unit need to be loosened and/or removed to accomplish this? Thanks for your help and Happy Easter!
Post A Followup
: Re: H bull gear/axle removal
