Re: pos. ground
Posted by Doug in OR on July 12, 2002 at 08:49:14 from (12.225.49.173):
In Reply to: pos. ground posted by dave welsch on July 12, 2002 at 05:48:49:
Another consideration is the charging system. You can run with a positive ground when using a generator, but finding an alternator that will work in a positive ground configuration will be more difficult. It's easy to make the change, though. Just reverse the battery, reverse the coil, repolarize the generator.. and you should be in business.
After changing to positive ground, you can add an alternator or electronic ignition at any time - no special, non standard, parts required.
Post A Followup
: Re: Re: pos. ground
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
