wiring problem still
Posted by dave welsch on July 23, 2002 at 06:55:39 from (208.32.170.140):
help! my h has the voltage regulator on the generator. i purchased a new wiring harness, three wires largest is blue next is yellow and the smallest is black. i have the yellow going from the voltage regulator(right side looking from the back of the voltage regulator) to the resistor on the light switch. blue from the middle of the voltage regulator to the ammeter. and the black going through the generator, coil and back to the switch and then to the fuse. also there is a wire from the fuse to the ammeter where the blue wire is connected. the tractor runs great, however i found out that the light box cover must be on the light box for the generator to charge (grounds the system i'm told)
so when i put the cover on the light box there is a spark and the needle goes right to d on the ammeter and it gets hot so i pull the cover off and it runs great. any ideas? i think my wiring job is off a little off
Post A Followup
: Re: wiring problem still
