SuperM cam gear and shaft
Posted by Bart on November 24, 2002 at 03:08:37 from (64.30.54.163):
Has anyone ever welded the cam gear to the cam gear shaft and had it work? Replaced cam gear and the woodruff key slot is all worn out because the gear was loose. It's either rekey the shaft or replace the shaft, either a major job with my limited resources. Not to mention taking the whole wide front end off to do the work. Any creative help out there? Thanks for any advice. (I know it should be done right to begin with but am trying to slide by with this one.)
Post A Followup
: Re: SuperM cam gear and shaft
