Re-installing the Crank Pulley
Posted by Brian on January 05, 2003 at 16:57:51 from (24.114.185.3):
What is the best way to install the pulley on the crank. I have looked in the achieves and it isn't all that clear.
I know there are two suggestions, one is to heat the pulley and pound on with 3lbs sledge, the other is to use the bolt tread in the crank.
My thoughts:
I've been told cranks are " brittle", if you ever dropped one it could crack. Therefore, what would pounding it with a sledge do ? furthermore..would this effect my brand new bearings ?
Thanks again.
Brian.
Post A Followup
: Re: Re-installing the Crank Pulley
