Re: Super A hydraulic pump
Posted by CNKS on March 10, 2003 at 18:34:41 from (207.178.96.212):
In Reply to: Super A hydraulic pump posted by Bob on March 10, 2003 at 15:22:58:
Don't know. Nothing much in those pumps except seals and gaskets, which are readily available from Case/IH. Unless the gears are stripped it should be fixable. You sure it's the pump? The hyd resevoir has a bunch of stuff in it that can be replaced also.
Post A Followup
: Re: Re: Super A hydraulic pump
