Farmall Tractors Discussion Board
Re: F-12 Starting problem
Posted by The Red on September 11, 1999 at 14:02:00 from (12.75.196.19):
In Reply to: F-12 Starting problem posted by Jason on September 11, 1999 at 13:28:58:
Jason even though fuel is getting to the carb, I wonder if the fuel pump is weak? If it runs well once started I doubt it is a manifold problem. When you are pulling it to start, you are probably cranking the engine faster then when you hand crank. That is why I think you have to troubleshoot the fuel pump.
Post a Followup
: Re: Re: F-12 Starting problem
