Farmall Tractors Discussion Board
F-12 Starting problem
Posted by Jason on September 11, 1999 at 13:28:58 from (152.163.204.47):
I have an F-12 that won't start by hand. I checked compression and it is at 55lbs. per cylinder. I also cleaned the carb, and points. It has great spark but will only start when pulled and has to turn over 3-6 times before it even attemps to start. Once it is running it runs great no missing or anything. If I shut it off and crank it imediatly it will start. But if I let it sit for any longer than 10 seconds it won't even attemp to start. Oh it also has good supply of fuel to carb. Any thoughts? HELP!!!. Thanks Jason
Post a Followup
: Re: F-12 Starting problem
