SMTA Clutch
Posted by Ernie Bob on May 04, 2003 at 22:38:30 from (198.81.26.239):
While putting my SMTA back together, after I had it split for TA work, I had a little trougle getting the splines lined up at the flywheel/clutch, I had some longer bolts drawing it in and I was turning the flywheel with a prybar. I was getting some resistance when all the sudden there was a popping sound and it pulled right together. I assumed that the splines were binding then they released. The problem is the clutch would not disengage when I got it running.
I just got it split again this evening. Anyone out there ever had this happen? Any thoughts what to look for? So far I have not seen anything that looks abnormal, although I haven't taken the pressure plate loose. Any input would be welcomed.
Thanks!
Ernie Bob
Post A Followup
: Re: SMTA Clutch
