Re: farmall a start switch/rod help.....
Posted by Hugh MacKay on June 18, 2003 at 02:41:19 from (216.208.58.126):
In Reply to: farmall a start switch/rod help..... posted by ken on June 18, 2003 at 00:11:06:
Ken: 99% of all A, SA, 100 and 130 have the type of starter switch that the rod is pulled for starting. The push type will work but I'll bet the rod you bought is not right length. The proper switch is the one in which you pull the rod. When buying a switch make sure you are also getting the little plastic shields that go inside the switch. I have run across 2 tractors in past year without those. Without those you can get a dead short in that switch.
Post A Followup
: Re: Re: farmall a start switch/rod help.....
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
