Farmall H Transmission fluid
Posted by Mark on August 15, 2003 at 14:47:02 from (205.188.209.140):
I drained the old transmission fluid (only about 1/2 gal came out). I refilled with new fluid and soon saw the new fluid leaking around the axle seals. I can see why it only had 1/2 gal left. My question is how difficult is it to replace the rear seals? Also, it is leaking around the pto shaft. Am I in over my head? Thanks for all your help. Mark
Post A Followup
: Re: Farmall H Transmission fluid
