Re: Farmall H Transmission fluid
Posted by Jailkeeper on August 15, 2003 at 15:17:33 from (216.174.160.141):
In Reply to: Farmall H Transmission fluid posted by Mark on August 15, 2003 at 14:47:02:
Are you aware there is more than one place to drain the fluid on an H? If you don't drain them all you will not get all of the oil out.
How much oil did you put in? What I'm getting at is if you didn't get it all drained and then put in 6 gallons, you would be way overfilled.
What type of fluid did you use? If you used Hy-tran, it will leak more than 80/90 would.
Post A Followup
: Re: Re: Farmall H Transmission fluid
