Farmall Tractors Discussion Board
Re: Alternator Problem - 10-S1 Type
Posted by ltf in nc on September 25, 1999 at 07:14:57 from (206.228.213.203):
In Reply to: Alternator Problem - 10-S1 Type posted by Village Blacksmith on September 24, 1999 at 18:52:43:
V B
The alternator is probably alright even after the beating. Your problem most likey comes from the method the alternator is wired. I have to assume this is a GM unit with the small connector/plug on the side. In order to help I need to know how or what is connected at this plug. If you have nothing, go to an auto supply and buy a two wire connector for a couple of bucks that fit this and repost.
Post a Followup
: Re: Re: Alternator Problem - 10-S1 Type
