Wiring in ameter panel on Farmall M???
Posted by novice on September 12, 2003 at 11:54:25 from (204.30.243.206):
Can anyone provide me with a wiring diagram of the back of the rotary light switch under the ameter gauge? My tractor's had a lot of the wires cut off and I am wanting to see how things hook up. My tractor has been converted to 12V neg ground. I just bought a rebuilt GM alternator with internal regulator (one wire connection) to replace the one that was on the tractor and want to be sure it's hooked up right. I understand the one wire goes to the battery, probably through the ameter so it can register flow direction (charge or discharge). I cannot read what is on the front of the ameter panel that IDs the switch positions cause it's all faded. What connects where?????
Post A Followup
: Re: Wiring in ameter panel on Farmall M???
