Re: Re: Oiling Problem
Posted by TDK on September 28, 2003 at 13:19:33 from (67.213.154.150):
In Reply to: Re: Oiling Problem posted by parts man on September 28, 2003 at 12:10:12:
Have seen people add a lock washer to these studs,parts book does'nt show any washers here.If lock washer is put on center stud oil will leak through gap in washer, resulting in little or most likely no oil getting to rocker arms.
Post A Followup
: Re: Re: Re: Oiling Problem
