Re: Oiling Problem
Posted by parts man on September 28, 2003 at 12:10:12 from (142.166.251.92):
In Reply to: Oiling Problem posted by Kevin In Michigan on September 28, 2003 at 10:18:06:
Kevin, I don't remember a gasket being there. Did you change the stud that holds the center rockershaft mount? That stud is hollow and carries the oil to the rockers. Check the bottom surface of it to see that there are no cracks and that it is flat.
Post A Followup
: Re: Re: Oiling Problem
