Re: Re: Re: 300 U Runs Hot
Posted by Charlie on October 28, 2003 at 13:56:04 from (209.130.221.120):
In Reply to: Re: Re: 300 U Runs Hot posted by H2O_Control_Guy on October 28, 2003 at 13:42:12:
Your tractor is definitely hurting if you can only pull those plows in 1st gear. I have a 300U that I pulled 2-14 trailer plows with and didn't hardly warm the tractor up. I would look at a couple of things before tearing the tractor apart. On the oil presure what kind of oil are you using. I don't know if the multweight oils will do what you describe. Worn bearings will cause low oil pressure when they warm up. I would check the engine compression. I don't know what it should be but I'm thinking a good cylinder should be over 100 psi. If the compression is good maybe the tractor needs a valve job. Does the tractor smoke when its running - smoking could be worn rings which should also mean lower compression. Is the tractor tuned up OK. Mine loses power when the points are bad. Running a little hotter spark plug helps with todays gas. If you start checking some things and ruling them out maybe we can give you some more ideas.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
