Re: Low Oil Pressure in Super A - Oil Pump?
Posted by scotty on November 26, 2003 at 05:35:17 from (199.231.49.128):
In Reply to: Low Oil Pressure in Super A - Oil Pump? posted by Slappy on November 26, 2003 at 04:44:02:
Slappy,
When I pulled the pan on my 49 Super A this past summer the oil pump housing was all cracked and broken, its only pot metal and I guess at sometime water got into the pan and cracked that housing. You might check that after yopu drop your pan. It sounds as if you have some oil pressure, these motors will run for years on a samll amount of pressure. While you have your pan off may as well check your bearings. Let me know how you make out.
scotty
Post A Followup
: Re: Re: Low Oil Pressure in Super A - Oil Pump?
