Re: Re: Low Oil Pressure in Super A - Oil Pump?
Posted by novice on November 26, 2003 at 05:53:37 from (62.189.158.225):
In Reply to: Re: Low Oil Pressure in Super A - Oil Pump? posted by scotty on November 26, 2003 at 05:35:17:
Scotty: I'd drop the pan and see if it has an oil pump gasket installed. If not, install your new one & see if the problem's solved. If theres one in there, then pump rebuild might be in order. May also want to Plasti-Gauge under rod cap bearing to eliminate loose clearance issue while pan is off if the gasket was found in place.
Post A Followup
: Re: Re: Re: Low Oil Pressure in Super A - Oil Pump?
