Mouse nest in Torque Tube
Posted by Hugh MacKay on December 07, 2003 at 15:06:22 from (209.226.247.132):
Last weekend I decided to start my tractors and give them a good warm up. In my Super A, I encountered a mouse building a nest in torque tube . He was using material from an old sofa cushion I find quite comfortable on SA seat for and old backside. Since I had the other tractors running and SA was last, I started it and immediately closed doors on shed, and left the tractors running. My thinking was that fumes and carbon monoxide would cause the mouse to rethink this location as a winter home. Corn and beans around me have all been harvested in past month.
Lo, I went to shed today and his home building continues. The little devil ran down the drawbar, me swiping at him with steel bar. He managed to avoid me. Using heavy wire and a screwdriver I removed about 2 quarts of his nest material. I then for want of a better material sprayed an ample supply of penetrating oil in torque tube from both ends. Just so he wouldn't decide to move I did the 130 and 140 as well.
Does anyone have some better suggestions? Mouse has got to go. A friend had this happen with Super C and started tractor without realizing mouse nest was there. It wound up in release bearing and presure plate fingers, breaking the fingers off presure plate as well as bending the activation lever to the release bearing. Costs a lot of time and money.
I guess I haven't been using tractor enough, and mouse decided some creature may as well use them.
Post A Followup
: Re: Mouse nest in Torque Tube
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
