Re: IH 444 Posi-traction hung up
Posted by parts man on January 05, 2004 at 19:33:37 from (207.179.175.24):
In Reply to: IH 444 Posi-traction hung up posted by Ken Kunkel on January 05, 2004 at 18:46:18:
Ken, on the back of the dif lock pedal is a small hook, put a light spring on that, just enough to bring the pedal back up to normal position.
The transmision shift lever on the 444s was softer metal than the earlier series of those tractors. Find a shift lever from a 434,424,414,275,276 and replace yours. That should help keep the gears from locking in.
You should also feel a little resistance when you shift gears, if not the detent balls and springs may be dirty and need cleaned. They are in the transmission cover between the rails and cover.
Post A Followup
: Re: Re: IH 444 Posi-traction hung up
