Saginaw 3 point
Posted by CNKS on February 08, 2004 at 18:04:36 from (207.178.99.234):
I have a Saginaw on my C and am very pleased with it. Considering one for my Super H. The pictures I have seen show the lower arms touching or nearly touching the drawbar. Does this present any problem in lowering the implement to the correct depth? Mike at Steel Wheel Ranch sells Cross 3 points -- says it has its own narrower drawbar, and that the arms clear the loop. You cannot use the swinging part with the Cross, and it only uses one hyd cylinder instead of two like the Saginaw. Costs about $100 less than the Saginaw (not important to me if it's not as good). Anyone have one of these?
Post A Followup
: Re: Saginaw 3 point
