350U Hydraulic Temp. Update
Posted by Ibby on June 05, 2004 at 04:00:48 from (64.14.92.197):
In an attempt to be brief, I didn't fully describe my system. When I purchased this tractor as junk, the power steering priority valve and safety regulator system was a fused piece of solid rust. (The plug on top was missing and it filled with water over the years)I was unable to find a replacement, so I removed ALL the original hydraulic valves and used the existing threads in the casting to lead the oil to a new priority flow divider and a brand new Prince 3 spool valve body mounted behind the seat. I used a 3/8 hose from the front pressure hole to a tee in the rear pressure hole, then 1/2" hoses to the valve. A 3/4 hose from the valve return side goes to the flow divider with a 3/8 going to the steering and the overflow goes into a 1/2 inch. The steering return and the divider return join into a 3/4 on the intake of the filter. (THe screen in the resevoir was missing, so I put a spin-on hydraulic filter on the return line to keep everything clean.) I also installed gauges on the pressure and return lines. THe high pressure side typically runs 300 psi during normal operations. (Up to 1500 when lifting a heavy load on the drawbar) The return side runs about 20 psi with a new filter, and I change the filter when it gets to around 60 psi. THe Prince flow divider is adjustable, and I backed it off until it just provided enough fluid for good steering response. The previous owner told me it always ran hot, and a friend with a 300U said his did too. THe pump was fine when I first started using this setup, but has started developing leaks that I blame on the heat. I'll have the pump rebuilt, but want to correct the heating problem before I do. I'd prefer to return this tractor to original, so If anyone can lead me to a proper valve setup, I's really appreciate it. I noted my 450 Farmall Row Crop with PS has a similier Priority flow valve but mounted differently. Is it the same valve, and could it be mounted on the utility version? If so, I may have more luck finding a Farmall 300, 350, 400, 450 valve setup. Failing that, I'd like to atleast get the oil temperature down with my current setup. Thanks for All your input. I appreciate any and all help provided.
Home
| Forums
Today's Featured Article -
Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
