Re: BD154 resleeving - help...
Posted by El Toro on June 15, 2004 at 07:51:09 from (205.188.117.22):
In Reply to: BD154 resleeving - help... posted by Greg on June 14, 2004 at 10:22:28:
Hi Greg, Did the tractor ever start after cooling off? Your radiator may have the fins blocked with dirt and hay. The radiator may need to be rodded. If you get it started hold your hand on the radiator to see if it gets hot all over. You can resleeve the engine by dropping the pan and removing the head unless the crankshaft needs machining. Then I would pull
the engine. I should've had that 9-ft sickle bar
when I was growing up. Good Luck, Hal
PS: Do a lot of checking before tearing into the
engine.,
Post a Followup
: Re: Re: BD154 resleeving - help...
