Farmall H coil 6 volt/ 12 volt difference?
Posted by Farm w/Junk on July 20, 2004 at 05:20:57 from (157.134.184.5):
Hi my tractor was running on 12 volts last summer and my coil went out so i put a 12 volt coil on it. It ran good and started nicely. Now that I have switched it back to 6 volt it starts hard but runs good if you get it started. Would the 12 volt coil not work as good as it should with 6 volts? What is the difference? Its from OEM tractor parts and looks like the original but is 12 volt. Should I order a new coil? Thanks
Matt
Post a Followup
: Re: Farmall H coil 6 volt/ 12 volt difference?
