Re: IH 560 D seems stuck in gear
Posted by minnimolineman on September 09, 2004 at 23:04:58 from (62.189.158.225):
In Reply to: Re: IH 560 D seems stuck in gear posted by Hugh MacKay on September 09, 2004 at 22:40:19:
They are OK as far as I know, never had any problem. Everything was operating normal when I parked it. It only sat for a month before I tried to start it. Even if the pressure plate was stuck somehow and the mainshaft rotating, the transmission in neutral should have prevented movement right? Like putting truck in neutral at a stoplight and letting out clutch to prevent wear on thow out bearing. I just can't figure how it's transmitting driving power to the axles. I have not forced the shift lever or anything to where the shifting forks got damaged.
Post a Followup
Subject:
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
