Farmall H Distributer: The Saga Continues
Posted by Red Dread on September 17, 2004 at 04:41:53 from (207.69.137.14):
You know, there is a reason for everything. I thought I had fixed the problem in my distributor by replacing a sheared distributor gear pin but I never even considered why it sheared in the first place. I had it all together after replacing the pin,it was sitting there idleing and all of a sudden the whole distributor started turning like a PTO shaft, ripping all my sparkplug wires and coil wire off in a tangled mess,(Go ahead laugh now it was kind of a comical sight). I removed the distributor and found it locked up tight. I took the distributor apart and found that a screw had worked loose from the plate that covers the advance weights and knocked one of the springs off and the spring was wedged between the wall of the distributor and one of the advance weights, locking it up. My guess is the screw had been out for a while causing the original pin to shear. This taught me a lesson in cause and effect.
Post a Followup
Subject:
