Re: Voltage regulator on an H
Posted by gene b on October 29, 2004 at 04:21:58 from (66.43.221.243):
In Reply to: Voltage regulator on an H posted by dave westlund on October 28, 2004 at 19:47:34:
Are you using 6v with a pos ground as the reg you should be using has to be that way. If you ground the field term on the gen it should show charge. You need to be more clear on what way you have the system hooked up.
Post a Followup
Subject:
