Farmall Tractors Discussion Board
Re: Re: Re: Ok...got the brake cover off and here is what I found -
Posted by Farmer Bob on November 17, 1999 at 20:07:10 from (207.227.187.183):
In Reply to: Re: Re: Ok...got the brake cover off and here is what I found - posted by Farmall Newbie on November 17, 1999 at 19:57:14:
You are quick...I was posting my second thought after I scrolled down. I think your oil is coming from a bad bull pinoin seal which sits behind the brake drom and band. You should see it around the large shaft that is sticking out of the tractor. The original seals are quite thick and if you replace them put two new ones in as they are about 1/2 the thickness. The old seals will be hard to remove but take your time so as not to damage the large bearing that's behind it. Those bearing are $50.00 each.
Post a Followup
: Re: Re: Re: Re: Ok...got the brake cover off and here is what I found -
